Revit 2016 to Rhino5 Problem
h_ghariby
h_ghariby
Hi
i have a project and i want to add some structural and architectural elements to my initial model, to model imported to revit and exploded well
but after i do importing revit model in rhino all surfaces change to untrimmed one( as u see in image) can anybody help me with this issue?!
also is there another workflow for working between revit and rhino? or even is it usual to export model from rhino to revit and import it again?! because i see a complex architectural geometry models that have a full structural and architectural elements!!!
Thanks a lot
Yien_Chao
h_ghariby
ok im test it (using dynamo and rhynamo) and here is resualt :
im not sure about a dynamo script but it convert a model to revit, the problem is that it makes a model open polysurface so im not able to explode a model!!( it dose not export some surfaces)
