REVIT 2016 release 2 bug
GuillaumeOja
Message 1 of 9
GuillaumeOja
Hi everybody,
First, sorry for my english, in french section there is no board for Revit.
Second, I've installed REVIT 2016 RELEASE 2 on my computer last week. All work fine, but I have an interface bug on family type window in family editor.
I can't rename or remove family type, because button are huge and we could only click on "New Type".
There is the same bug for family parameters on left bottom.
In attach files, 2 screenshots with both bugs.
Thank you !
Replies (8)
Message 2 of 9
dzanta
I have installed R2 on several computers and the interface does not show these errors.  Have you tried uninstalling and reinstalling R2?  Have you tried repairing Revit?  Have you updated your graphics card driver?  Have you changed your resolution from the highest setting down to a lower setting and back?
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn |
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
Message 3 of 9
GuillaumeOja
I have updated my graphic card driver to the last version (from 10-27-2015) -> Nothing change
I have repaired Revit -> Nothing change
I have changed my resolution setting like you proposed -> Nothing change
For installing R2, I have to uninstall Revit and reinstall it (because my SP2 build number was wrong...) so I think it is not the solution.
Message 4 of 9
dzanta
Then there may be a bug in the software.  I would gather the following information and send it to Autodesk Tech Support via email so they can investigate and get back to you:
1.  Revit version and build
2.  Product serial number/key
3.  Client Name/Company Name
4.  Address
5.  Phone and email
6.  Exact nature of issue
Message 5 of 9
glallier
I have the same problem. It is coming from the french version.
When I change to English the problem is gone.
Message 6 of 9
glallier
Bonjour Guillaume,
Si tu désires éviter ce bug, if faut mettre ton Revit en anglais, le temps qu'ils solutionnent le problème.
Comme tu le sais peut-être, il suffit de faire comme ceci.:
Il faut changer les trois lettre :FRA pour ENU dans les propriétés du logiciel en faisant un clic droit sur l'icone de lancement de Revit.ENU.png
Pas besoin de réinstaller ou quoi que ce soit.
Message 7 of 9
GuillaumeOja
Merveilleux !
Ca m'obligera à perfectionner mon anglais comme ça !
Wonderfull !
I will improve my english so !
Message 8 of 9
glallier
DZANTA
FYI
The french version of R2 is bugged.
The place where it shows is in the family parameter box, where the changes happened in R2.
Message 9 of 9
patrick.emin
Bonjour,
Il existe désormais un forum Revit en français.
Patrick Emin animateur de la communauté francophone
Vous avez trouvé un message utile? Alors donnez un "J'aime" à ce message!
Votre question a eu une réponse satisfaisante? Voulez vous avoir l'amabilité de cliquer sur le bouton
 APPROUVER LA SOLUTION  en bas de la réponse qui apporte une solution?
Signez notre Livre d'Or
