Crashes Revit Central File
asab1409
asab1409
When I open Central file from Network Drive. It is taking too much time to open to create a local file.
And when I am creating a MONOLITHIC STAIR the revit is crashing suddenly.
J450NP13
Save a local copy on your machine and sync to the network central file.   Do not work off the network file.
What is your network connection to the server/central file?
If you are working wirelessly or on a 100mb connection you will experience terrible slowdowns and central file traffic that will bring Revit to a crawl.
Also run an Audit on the central file and check for warnings.  If there are a lot of warnings, have someone fix them so you can access the model.
