Revit 2015- unrecoverable error
Start Revit 2015 error"An unrecoverable error has occurred.  The program will now be terminated.  All of your data has been recently saved, so there is no need to create recovery files"
ennujozlagam
Hello. Before you open your files tick "audit" if this helps. Thanks
hello sir,
same problem show on revit 2015 when open file
i will check audit and open file but not work file is corrupted when check audit
pls if any solution so i will resolved problem
Viveka_CD
Hi @Anonymous and @Anonymous
Sorry to hear that you are facing issues with the application.
Please see HERE for a related article
@Anonymous Can you please share your journal file, this will help us troubleshoot further.
Can you confirm if you have installed the latest updates for your Revit version? See HERE and HERE for more information on how to update Revit 2015 to the latest version.
To install updates, open the Autodesk desktop app and click My Updates. To install a new version of your Autodesk software, open the Autodesk desktop app, sign in, and click My Products. To use a web browser to install updates or a new version, sign in to Autodesk Account
Let me know if you were able to resolve the issue.
Please mark this response as "Accept as Solution" if it answers your question to help other members seeking similar solutions. Kudos gladly accepted.
thanks Viveka
Revit file open successfully
Problem is resoled
Viveka_CD
Hi @Anonymous
I am glad to hear that your issue has been resolved. Smiley Happy
Let me know if you have additional questions.
