Revit 2015 Properties Box Issue:
Not sure if this is the correct spot for this kind of question.
Whenever I try to enlarge my Properties Dialogue Box, it will inevitably change to look like the attached screenshot.
It will do this on either of my two screens.  Has anybody encountered this before and/or have a solution.
Thanks in advance for any responses!
What are your​ screen resolutions and display scaling?
Undock the properties window and move it around a bit on the screen...then put it back.
Even better...if you have multiple screens place it on the other one.
A_MAQ
Yes I have encountered this issue many times ,
move it right or left again it will be ok
best,
Autodesk Expert Elite
Viveka_CD
Hi @Anonymous
In some cases when the Properties palette and/or Project browser are moved to a second monitor and the monitor gets disconnected, it becomes impossible to drag them back to the monitor which hosts the application.
Attempting to deactivate then reactivate the Properties palette or Project browser or from the Ribbon (View > Windows > User Interface) does not work.
Please try the following steps:
1. Make sure Revit is not running.
2. Using the Windows Registry editor, select and delete the following key:
  • HKEY_CURRENT_USER\Software\Autodesk\Revit\Autodesk Revit {Product Name} {version}
  • Replace {Product Name} with Architecture, Structure, or MEP or leave blank for Revit OneBox.
  • Replace {version} with your release of Revit 2015
3. Relaunch Revit
Try to keep them both stretched at 100% height on a secondary monitor and stack them at 50% vertically on the second monitor and then 50% vertically on your primary monitor.
For a similar issue discussed in the forum see HERE
