Hi
I download offline helpe revit 2015 ,But the CAB format .
How can I use??
Downloading and installing offline help is part of the installation process. It is a selection made at the time of install. You can do a repair or re-install of Revit and during the installation mark that you want offline help installed. Once installed it will work automatically when you are not connected to the internet, the locally installed help will be called instead.
