Hello
My MEP link has turned gray, like half tone, but it isn't set to be. I have tried to override the objects to black. I checked for filters. I checked the object styles. I checked for overrides. I check phases.
Any Ideas what might be happening here. They changed over night. Was there a Revit 2015 update that may have triggered this? I have see several odd graphics issues lately; Mostly with windows.
Thanks for the help
Nardo
john.vellek has edited your subject line for clarity:Link is gray, but I don't know why
Hello
Thanks for the help
Nardo
Hi @Anonymous,
I assume you have checked here in VG.
is this appearing in all views?
Can you attach the files (or stripped down versions) so I can try to duplicate and resolve for you?
Hi @Anonymous,
John,
I finally found a hidden plan region that had the view depth way to low. Once corrected everything looked fine.
Thanks for your offer to review my model.
Nardo
John,
Nardo
Once I had also the same halftoned issue with linked projects.
Tried everything, finally found out, that in the linked model there was a model in-place (mass models? sorry, I don't have the english revit right now) throughout all the linked model.
Due to this, some elements in the linked model was halftoned (elements inside of this model in-place [mass model?]), but others — not halftoned.
So, I just switched off the visibility of model in-place (mass model?) category for the linked project.
