REVIT 2015 - An unrecoverable error has occurred
I was working on the project and power shuts unexpectdley ,when i open it later it says unrecoverable error occurred and closes with error report.
i try to open the file on another machine ,open another user account, reinstall the product none of these works..if anyone know the problem please let me know
rudi.roux
Hi @Anonymous
Welcome to the community! Smiley Happy
It generally relates to a corrupt user profile. Have a look at THIS POST for causes and solutions. THIS POST may contain some of the related issues which you experience prior to receiving the error message.
If none of the above helped, then it might not just be the user profile, but the file itself (likely culprit).
  • Try and open the file from the Revit Button, search for the file and prior to opening, select the "Audit" option. Then select "Yes".
  • Try and turn of hardware acceleration prior to opening the file. Revit Button >> Options>> Graphics.
  • Is your service packs up to date?
I hope this helps! Smiley Happy
Rudi Roux
MSc | Digital Engineering Manager
LinkedIn
Revit Mechanical & Electrical Systems 2018 Certified Professional | Revit MEP & Architecture 2015 Certified Professional
AutoCAD 2015 Certified Professional | Autodesk Building Performance Analysis (BPA) Certificate
If this post resolved your issue, kindly Accept as the Solution below. Kudos are always welcome
Thanks it was service pack update issue... Think you
rudi.roux
Hi @Anonymous,
I'm glad to hear that your issue is resolved. If you could be so kind and Accept as Solution below the post which helped you so that future community members can benefit from it. Check your Autodesk Desktop App on a regular basis for Service Pack or other Autodesk related updates.
Have a great day!! Smiley Happy
Rudi Roux
LinkedIn
