Hi All,
I am having problems trying to open Revit 2014.
The splash screen loads and the software appears to open, only to immediately crash.
This happens every time I try to open Revit 2014.
I have uninstalled and reinstalled Revit numerous times along with the relevant update releases and I am still experiencing these issues.
Has any one else experienced this and is there a solution, as we currently have live projects in 2014 and are unable to deliver.
Solved by Viveka_CD. Go to Solution.
@Anonymous if you have installed third party software (add-in) try to uninstall it could be the caused of the problem, could be some are corrupted., if you run the Revit program without problem then install back your add-in software one by one and see if helps. thanks
Hi @Anonymous
Sorry to note that you are experiencing crashes when opening Revit.
If you still continue to experience crashes let us know.
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
I relocated the plugins located in the folder -
C:\ProgramData\Autodesk\Revit\Addins\2014
and rebooted Revit 201 and all worked fine.
I found the issue to be with the plugin Cloudworx.
