After you have done your listed steps and adjusted your project "up" 100', you need to do one more thing.
Highlight one of the Level lines in an elevation or section view. In the Properties box, pick Edit Type. In the Type Properties dialog box, change the Elevation Base parameter from Project to Shared.
Your Level elevations should now show the new elevations.
Douglas Bowers, AIA, LEED AP
Revit Architecture 2016 Certified Professional
Revit Structure 2016 Certified Professional
Revit MEP 2016 Certified Professional
AutoCAD 2016 Certified Professional
www.dougbowersconsulting.com
blog: http://aectechtalk.wordpress.com
Please use Mark Solutions > Accept as Solution and Give Kudos as appropriate to further enhance these forums. Thank you!
