Reverse Door opening in External Door
eddymyers
Message 1 of 10
eddymyers
Hi there everyone - just learning and using Revit 2012. I have inserted an external door - no problem, I have reversed the swing of the door but this then makes the external cill on the inside of the wall - how can i change the opening swing of an external door and keep the internal/external correct?
Thanks in advance
Eddy
Replies (9)
Message 2 of 10
These controls don't work correctly?
Message 3 of 10
eddymyers
They flip the whole door set and bring the cill to the internal side of the external wall
Message 4 of 10
I'm not following you. Got pictures? Sounds like you what to flip the "cil" independently. Is that right?
...if I am reading you right, you may need model two "cil" conditions in the Family and use Visibility Parameters to control which one is visible.
Message 5 of 10
eddymyers
You know how there is an 'outside' to an external door and there is an 'inside' to the door? This is differentiated by the cill and the position of the door frame within the external wall. I want the 'outside' of the door to be on the outside of the wall but the door is to open outwards....If you flip the door, it moves the cill to the inside face of the external wall - it doesn't just make the door open outwards
Message 6 of 10
First of all, re-read my above post. I edited it.
Second, post the door family (RFA) here.  Know how?
Message 7 of 10
eddymyers
This cannot be the first time someone has wanted to insert an external door and have the door open outwards???
Message 8 of 10
eddymyers
No, I don't know how to post the RFA.....It is a standard one from Revit though
Message 9 of 10
mhiserZFHXS
The easiest quick fix for you will probably be to open the family and switch the side the cill is on. You'll want to save it as a new family though, because it will switch ALL doors of that family if you just switch it and reload it. So switch, save as new family, and load into project.
The way flipping doors works in Revit isn't just flipping the swing. It actually flips the entire family, as you've discovered here. But you can absolutely create a custom family that allows things like the cill side to be controlled. I would encourage you to go down that rabbit hole if you have the time.
Message 10 of 10
Which "Standard" one?  Give us a name.
Also, to post a File, start a reply post and scroll down to "Attachments" as shown in this screenshot:
