Hello to everyone,
I am at the moment having some issues with a section of the retaining wall that I have modelled to go throught the level -3 into the level -2. As you can see throught the picture in this section the retaining wall ain´t connecting with the floor as it happens with the other sections of the retaining walls. Does anyone understand why this is happening... I tryied to use the option "Top offset" but it didnt worked. Either way it shouldn´tbe resolved throught this way since the other sections o the retaining wall are connecting with the floor of the level -2.
Best regards
are the other sections joined to the floor using attached top/base? rather than just going up to the level -2 or is there maybe something hidden that its attaching itself to?
Hard to understand or see what you are describing. Are you wanting to Attach the Wall to the Floor?
@Anonymous, it worked. what about this one... here is the picture, I am trying to attach the retaining wall to the floors.
best regards
Excellent! Whats the issue with this one? its hard to see from your image?
I want the retaining wall to go all way up until it meets the structural floor. You can see that there is a gap or a small piece of the floor that is undercovered... I do not want this anymore... but it seems that the walls can´t attach to the floors. do you have any other option that allow me to do this?
best regards
If there are other walls behaving property, and just this one isn't -- try using Match Type Properties Tool on Modify Tab. Or, maybe, delete and redo the wall?
....Reveal Hidden Constraints might reveal the reason it ain't attaching.
1. Check if the wall Top constraint is that upper level, fix the " TOP OFFSET " probably its in negative, thats why you see that gap..
2. Once any wall is attached to any FLOOR ( base ), ROOF or upper FLOOR ( top ), then instance properties like
top offset, and bottom offset won't work, cause it get overridden with " ATTACHED"
3. Also if any wall is edited with " PROFILE " then nothing else will work, you need to reset the wall, check the
top/bottom attachment, DETACH if required.. and use instance properties of TOP and BOTTOM offset..
4. Offsets can be Positive or negative ...
hope that helps..
@Corsten.Au, I do not understand what is happening.. I domt have any top offset and I also cant attach my retaining wall to the floor.
