Residential Roof Connection
Message 1 of 16
I am working on an addition to a house and I am trying to connect the new roof to the existing one. I cannot figure out how to design the roof properly so the two can be connected. Ideally the new roof would be a hip roof to match the current style. In the screenshot, the new roof has the shingles on it.
Replies (15)
Message 2 of 16
Post the file.
Message 3 of 16
Just posted!
Message 4 of 16
What about just joining them together?
with -7" Offset so eaves align...
Message 5 of 16
constantin.stroescu
in my opinion , this is the correct connection of the two roofs...
In roof design you are not allowed to have horizontal valleys...
Constantin Stroescu
Message 6 of 16
Diverter.
Message 7 of 16
I do not know how you were able to connect these. I have tried to join them and I cannot do so. Can you upload your file?
Message 8 of 16
I don't believe he connected the Roofs.  I think he demolished and replaced the Existing Roof with the Rood that he is showing in his screenshot.
Message 9 of 16
costelos
it's in Revit 2019
  • the same slopes for the Faces that has to align
Message 10 of 16
constantin.stroescu
sorry, I've sent the answer for another account of mine ( the office one)
Constantin Stroescu
Message 11 of 16
Message 12 of 16
Ah! So you're the infamous @costelos.  Is that your Porn Star name. he, he.
Message 13 of 16
constantin.stroescu
Oh , yes...my other name is Dr.Jekill...or should be Mr. Hyde?
I don't remember anymore....I'm totally confused...No,no...now I remember , yes is dr. Alzheimer...
Constantin Stroescu
Message 14 of 16
Is it normal practice to connect the existing and new roof like that in Revit to send to the contractor? I am trying to make sure I am completing this correctly.
thank you all so much for the help! I am a graduate Architecture student assisting with a home project and I do not have a lot of experience with residential roofs.
Message 15 of 16
constantin.stroescu
In practice on site,the constructor use to make a partial demolition  in the junction area of the existing roof with the future roof ( slightly wider that the final junction area)
Usually it will uncover the roof structure (to let only the rafters)
New rafters will be placed so to connect with the existing ones (they will make some trimming on the existing wood structure) and then rebuild the roof .
Finally rebuild the non structural outer layers of the roof so to join with existing ones.
In many cases I had, this was an opportunity to make a structure revision of the existing roof and , also, sometimes , to change the entire surface of exterior finish layers.
Constantin Stroescu
Message 16 of 16
@Anonymous:  Google "California Framed Roof". This is likely how it will be constructed, unless you plan it differently.  But, more importantly, research jurisdictional building codes. In my neck of the woods, their are slight differences in how overbuilds are framed between county lines.
