Reporting Parameter Host Error
- Mute
- Permalink
- Report
Hi all,
I'm editing an existing family and am trying to output a value in a tag.
The casework component has been modelled a long time ago, it's a typical bench/vanity setup.
I am trying to get the width value to read in a project when I tag it. For example, an 1800mm wide vanity would tag as '1800v'.
So far I have added a reporting parameter and assigned it to an additional dimension.
I have then added my tag parameter and am trying to use a formula for it to read the reporting parameter but I get an error.
"A reporting parameter can be used in a formula only if its dimension references are all to host elements in the family."
From doing some searching, I can't use reference lines for the dimension, so I have changed the dimension to read the modelled items but I get the same result.
I have no idea what the 'host element' is in a casework family. I've even tried using the reference level (in a different axis) with no luck.
Can someone please assist?
I feel like I'm really close and just missing one silly thing.
