Report a door in a room schedule
Message 1 of 10
Is it possible to report the door that is associated with a room in a room schedule?
Replies (9)
Message 2 of 10
No. But you can create door schedule with the associated Room information.  How do you want the schedule to look?
Edit:  You probably can with Dynamo.
Message 3 of 10
Well, we are a BIM consulting firm, and the architect wants our recommendation. So I'm supposed to decide how it looks. I've never really seen people make a "room" schedule per say. I mean I'm always used to seeing a door schedule with the room mark in that schedule. This is a storage facility. I'll show you what they started. I think I'm recommending this be done with a door schedule. what are your thoughts?
Message 4 of 10
I would use a Door schedule with Room data. Sort by Room number/name and change the Title and you are good to go.
Message 5 of 10
Alfredo_Medina
Yes, it is possible to embed the door information in the room schedule.
in this example, the headers highlighted in blue refer to the room, and the headers highlighted in yellow refer to the doors in each room.
Message 6 of 10
Good thought on using the embedded schedule! I have found it difficult to format the way I like but it maybe exactly what OP needs.
Message 7 of 10
Alfredo, how in the hey did you do that?
Message 8 of 10
@Alfredo_Medina have you seen the screen cast add in for Revit? Would you mind screen casting that process on here for me please?
Message 9 of 10
See the screencast.  Credit still goes to Alfredo.
Message 10 of 10
Thank you very much @Alfredo_Medina and @ToanDN !!!!!!!!!!!!!
Can you also report a ceiling height?
