purge
12 ANTWORTEN 12
Nachricht 1 von 13
572 Aufrufe, 12 Antworten
purge
Hi.
I want to ask for help, I need to use quickly my revit documents, I want know how to clean my archives like in Autocad I can used "purge" for clean the archive. How I clean the archives in Revit? thanks for helping me.
12 ANTWORTEN 12
Nachricht 2 von 13
als Antwort auf: Anonymous
manage tab > Purge Unused
Nachricht 3 von 13
m.voss.alvine
als Antwort auf: ToanDN
are you wanting to clean the model or clean within your directory?
Revit MEP 2015 Certified Professional
Revit Architecture 2015 Certified Professional
AutoCAD 2015 Certified Professional
remember to 'accept as solution' if this helped
Nachricht 4 von 13
als Antwort auf: m.voss.alvine
Hi.
I want to clean the model, because the file is so heavy, and is difficult open it.
Nachricht 5 von 13
Not only purge but make sure you dont have a thousand CAD links attached to the model. These will make the model heavier.
Nachricht 6 von 13
@Anonymous wrote:
Hi.
See comment #2 in this thread.
Nachricht 7 von 13
RDAOU
How heavy? You need to watch what you are purging...purge in Revit does clean up things but it is not meant to be used as Purge All in AutoCAD...so if you use it, do use it with caution.
1. You need to look more into what you are modeling and how you are modeling ex: excessive use of swept blends and adaptive components makes your model super heavy when lots of elements do not need to be modeled that way ... And Purge does nothing to fix that
2. If you model your site (along with external works/furniture) and building within same model, you would be making the model heavier when you don't need to...it is recommended to model the former and the latter separately in two different models
3. Another example is using exploded CAD imports instead of links...the former loads your model up with useless objects some of which Purge doesn't clean (ex: unused imported patterns from CAD)
Purge will not really improve the performance if examples similar to the above apply...you might want to consider upgrading your hardware too if you are looking for performance
We work with models ranging between 250-500mb in size and we don't consider them heavy...
Nachricht 8 von 13
Hi.
Yes, I used some cad model, for that I want to can be able to purge the file for made it heaviest
Nachricht 9 von 13
In my opinion CADs should only be used as a temporary thing while modeling and not a permanent thing. Try to keep them at a minimum in your model. If your consultants are working in CAD and you need to import their work make sure you bring in what is needed only. I purge the cads and create w-block of the area I need before bringing the CAD into revit. These are typically the culprit of "heavy" models. Make sure the CAD doesn't have a bunch of xrefs as these will also be read on revit and thus making it heavier. Do you know how to remove / unload them?
Nachricht 10 von 13
thanks, No I don't know how to remove this files....
Nachricht 11 von 13
EmptySaturnV
If I want to do a complete clean up of a Revit file, I will use purge, audit, and compact file.
to audit: click here
to compact: save-as, then open the options, select the "compact file" button, then save using the same name.
Nachricht 12 von 13
Ok, if the file is a link then either unpin it and delete it or go to: Inserts - Manage links - CAD Formats and either unload or remove. If the CAD is an import then you have to delete them from the view. Just click on the CAD and hit "Delete". Hope that helps. Typically CADs are the things that make a Revit file slow and big. If that doesn't work, try purging all unused items.  Go to Manage - Purge Unused. A window will open and you can manually deselect things you rather keep.
Nachricht 13 von 13
als Antwort auf: EmptySaturnV
Thank I try it.Katze (glücklich)
