For half an hour I have been trying to put the Project browser back on the left. Above the other browser. I'm sure it's easy. Thank you in advance!!
Solved by _Vijay. Go to Solution.
Solved by syman2000. Go to Solution.
At the project browser, you should be able to hold and drag the menu
Keep holding the menu and drag it to the side until you see blue highlight. Then release you button and the menu will drop back in place.
Finally I found an answer. The side attachment option only became available when I carried the revit window to the main computer's screen. It wouldn't detect the side edge on extended monitors.
