renumbering doors to match room numbers using add in tools
rclement
rclement
im trying to get better using revit by using residential design using revit  2019 in ch 13
initially i used tag on placement so the doors were incrementally done np. it says you can manually renumber doors
cool i have np with that either. but is sdays for fyi you can renumber using revit add on tools.
ok where are add on tools. and how do i know if i have to install it or i have already have it. and where is it on ribbon
and if i dont have it installed where do i find the add on tools?
rclement
also when over wtiting door tags i get a message changing parameter why so?
Hard to understand what you are asking. Are you looking for an add-in that will renumber. Google for "pyRevit".
...Revit use to have a renumbering tool in their REX, but it's no longer available.
just google "match door number room number revit dynamo"
What's the message?
This one?
...or this one?
...or this one:
