Rendering Yellow
Rendering Yellow
Rendering Yellow
When I am rendering the view everything is getting a yellowish tone. But not everything is yellow on the scene. Maybe the floor and some furniture but not the walls or the chair or the desk. I saw a couple of renderings around the forum and I know that this is wrong. Please I need an explanation or help. Thanks.
ennujozlagam
check you materials setting? it could one of you materials reflectance or glossiness setting need adjustment? share your file so we can check. thanks
aRcHiTeCt.JM
…. hi @Anonymous
…. do you mind uploading your model to take a look?
….but … in the meantime try these:
1 – go and check the intensity of the lights in your project
… click on any light in the ceiling
… edit type
…. edit the properties
… maybe they are too high
2 - go and check the exposure value in the rendering
… when rendering click adjust exposure
…. and in exposure control
….. tweak these settings
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
Thank you. I am just using the library that comes with revit. I did not change any material. I don’t even know how.
Thank you. I don’t have lights in my project yet. I am just rendering in the sun only option. I did find that the rendering was getting too yellow because the exposure was too high as you mentioned. I am moving all those values down and I am getting the right image.
Final Image.
Initial color is the setting we are looking for
