Rendering water
Rendering water
Rendering water
Hi!
I'm trying to render a parallel perspective plan view (i.e. from a camera directly above its target) and I have a body of water that i used the Revit water material on but it's rendering totally flat. Any suggestions as to why and how I can fix it?
Thanks.
chrisplyler
I'm guessing you modeled it flat?
The problem is likely your Rendering Appearance Image/Settings if it isn't "Flat" in other Visual Styles. Can you post a screenshot of that Dialog Box?
...also, are you rendering with enough light?
Did you import the correct assets?
I did a quick test and why the color may not be nice, it certainly ins't flat.
