Rendering up to 5 Gb ? Help :(
hello guys, i almost complete my project, then i want to try render it, but it got 5 gb 😞
why it is so big just for 1 image?
if i use the Screen option, the pixel will get too low, and the image result were so bad.
it is normal ?
RDAOU
@Anonymous
Try changing the render resolution DPI
Try changing the scale of the view too 1/50 instead 1/10 which shows in your screenshot
You can also try rendering using Lumion or Enscape (much better results)
Check other option on the following link
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2020/ENU/Revit-DocumentPresent/files/GUID-9F35FD0E-EF9B-4BB9-8CF7-6F8A6280CCAC-htm.html
Yeaah i got it, when i change the scale to 1:100 the size get smaller to 60
Mb, thanks a lot
