windows and doors legends
10 ANTWORTEN 10
GELÖST
Nachricht 1 von 11
basma_salman
2308 Aufrufe, 10 Antworten
hello,
I would like to know if it is possible to display the information of doors or windows automatically when placed in a legend view instead of writing it manually by texts
10 ANTWORTEN 10
Nachricht 2 von 11
RDAOU
als Antwort auf: basma_salman
No. Not in legend view. Those are very basic non-intelligent views.
There are several alternatives though...for instance you can use assemblies and assembly views those can serve as legends and are live linked to the model element
Nachricht 3 von 11
basma_salman
als Antwort auf: RDAOU
yes i'm using assemblies for curtain walls and so, but for doors and windows I do not know what to do abt them
Nachricht 4 von 11
RDAOU
Have you tried using 3rd party extensions/plug ins? there are some which create dynamic Legends displaying doors' elevations with parameters such as Type Mark/Type Comments...as a matter of fact there is one on Autodesk Store called Dynamic Legends, another is Tools4Revit
An alternative also would be Phasing...using live model elements set to a Phase before Existing or before New Construction (Created and demolished same phase) where those elements are used as a Type Legends and it works for all families
Nachricht 5 von 11
basma_salman
you mean for ex: I select a door in my plan, and then choose it phase, and then what?
Nachricht 6 von 11
RDAOU
I mean the following:
  • Go to Manage >> Phasing
  • Create a Phase (should be first in the linst) call it lets say "Legend Elements"
  • Create another Phase (place 2 in the list) call it "Demolish Legend"
  • Create views and set them to "Legend Elements"
  • Set phasing filters "show all"
  • Place all the all the elements you want to annotate (Phase created would be in this case "Legend Elements"
  • Set the Demolished Parameter of the above elements "Demolish Legend"
    • When you do that, those elements will not show on the schedules/quantities of the New Construction phase.
Tag and annotate plan views and elevations of those elements (callout details...), place on a sheet and use as a live legend...whenever u change anything to the types or type comments those update automatically
I'm sure you can find some youtubes on this topic because it is quite a common methods may use or at least used to use if they are not using a plugin that does something similar
Nachricht 7 von 11
basma_salman
this is a time consuming and not practical,
thank u anyways, I will mark ur solution:strahlendes_Gesicht_mit_lächelnden_Augen:
Nachricht 8 von 11
RDAOU
@basma_salman
You can download the Plugin trial version and try it out see link below to Autodesk App Store...
Dynamic Legend on App Store:
https://apps.autodesk.com/RVT/en/Detail/Index?id=1560070584580852683&appLang=en&os=Win64
Or
Nachricht 9 von 11
martijn_pater
@RDAOU Interesting use of phasing. ^^ That's a nice trick.
Nachricht 10 von 11
RDAOU
als Antwort auf: martijn_pater
@martijn_pateryeah and it comes for free :leicht_lächelndes_Gesicht:
Nachricht 11 von 11
I always put the Legend Phase at the bottom of the Phase list and set the Legend views to Show New only.
