Rendering Material Not showing
5 REPLIES 5
jayhar
416 Views, 5 Replies
Refer both images, material not appearances in Revit 2024. some file are missing
How to Solve this?
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
5 REPLIES 5
in reply to: jayhar
Were they available in prior versions?
...is there an "Oxford Cherry-Horizontal.jpg" on your computer somewhere?  If so, move it to your C:\Program Files\Common Files\Autodesk Shared\Materials\Textures\3\Mats Folder, or add its location to Additional Render Appearance Paths.
Help: Additional Render Appearance Paths (autodesk.com)
syman2000
in reply to: jayhar
Looks like custom material missing from your library. If you have those material in a specific folder, you want to add the folder to the rendering setting under Revit options
jayhar
in reply to: jayhar
Oxford Cherry-Horizontal.jpg and all image is missing, no files
in reply to: jayhar
Well then, sorry to say, you're SOL.
jayhar
in reply to: barthbradley
"SOL" stands for ?????
