Cut Profile line color/visibility graphic settings
4 ANTWORTEN 4
Nachricht 1 von 5
BarryBinns
3685 Aufrufe, 4 Antworten
Hello all,
I used the Cut Profile tool to adjust a finish layer of a wall in a section. I did this to bring the finish up above the tapered insulation in the detail and am getting a green lines where the profile of the wall was removed. None of the visibility graphics settings for walls has green in the settings and I cannot find where this green graphic is defined. How do I change the visibility graphics of the cut profile elements? I know they are supposed to adopt the graphics of the element cut but this does appear to be the case here.
I've checked the view template
I've checked the object styles
This one is completely escaping me so I'm hoping this is a simple fix.
Thank you ahead of time for your assistance on this issue.
Revit 2019.1
Barry
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: BarryBinns
It's the Course View Representation for the Cut Profile.
Do you know that that you can unlock that wall layer in Edit Assembly Section Preview? This will allow you to extend that layer up or down via the "Base Extension Distance" Parameter.
Nachricht 3 von 5
BarryBinns
als Antwort auf: barthbradley
Yes, in fact the exterior layers are unlocked on this wall type and that feature is utilized in this detail. The problem with this detail is that it needs a second base layer offset for the exterior stucco finish to stop or be held 2" above the roof while the zip sheathing and insulation layers extend down to the roof deck. The wall continues on below the roof and is cutoff in the snapshot I provided.
Hence my little green alien line!
I suppose I could just use a masking region and reset the cut profile.
Thank you though...
Nachricht 4 von 5
cdavis_eyrc
Anyone ever find a solution to this? I'm having the same issue. I cant find where to override the visibility settings for the cut profiles. it only shows up in my wall sections.
Nachricht 5 von 5
Same for me, can't seem to find this setting
