Rendering in VRay with a background image in Revit
I have inserted a background image in Revit for a rendering and am using VRay to render the image. When I render, the background image is not showing up.
I inserted the background image from the Graphic Display option in the properties dialog in the 3D view that I want to render.
Is there something else that I need to do to make the image show up in my rendering?
aRcHiTeCt.JM
… hi @Anonymous
… it is because V-ray doesn’t work like that
… as I’ve been saying try to stick with the REVIT engine
… or try ENSCAPE … the results are better and way faster
… V-ray will not be reading your REVIT background image
... or any material that is not from REVIT itself
… doesn’t work like that … at least up to now …
… if you want to get your own image as a background
… you will need to load it as a decal
… decal outside as a background
how to place a decal in a view
… or you can try as a material (but this option is way too much complicated)
… the assets editor material is kind of complicated
… V-ray for REVIT is still in development
… and will keep that way for a long time
… my advice: stay with REVIT engine or ENSCAPE
.... or go and ask in the V-ray for REVIT forum
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
