Revit Coordinates and Performans
1 ANTWORT 1
Nachricht 1 von 2
235 Aufrufe, 1 Antwort
Our company has to make lot of Master plans with Revit program and many people have to enter that centeral model.
We tried some solutions to boost the performance of the centeral file model but did not help, so we are reaching you to help us in finding a solution to our problem.
So, we are going to tell our two problems with pictures.
Hopefully, you could understand and help to us.
1-
            Picture 1 (This drawing is the copyright of Studio Vertebra and must not be retained, copied, changed or used without Studio Vertebra's authority.)
This is one of our not that big master project. (picture 1)
We use same blocks all the plans as you see in the picture 1 and we draw all model by shared coordinates.
             Picture 2 (This drawing is the copyright of Studio Vertebra and must not be retained, copied, changed or used without Studio Vertebra's authority.)
We want to have building A1 block as a  one Revit file and use it in all of the project same model but using 5 different coordinates. As you see in picture 2, we are modeling the highlited  A1 block and want to use the same model in the coordinates of the  blocks no : 2, 3, 4 and 5
When we want to be able to hide and show other models on different coordinates from the  properties window in the main model.
We use one method which is 5 different file and 5 different coordinates for A1 block in the main model. When we want to bind files and send to our employers, the main model stops working because  model disappear and we couldn't find it anymore.
2-
We use central model with links and when the files size become over 100 mb, we make new file and we purge all nested items which are group, family , etc..
But we don't have good performans (too slow model, not easy use model, etc)
So, how could you solve our problems?
Thanks for attention,
Sincerely,
Mina Yamanlı
1 ANTWORT 1
Nachricht 2 von 2
als Antwort auf: Anonymous
