Rendering dialog box
I'm using Revit 2015 and my rendering dialog box is locked.  I am trying to change the background so it is white, but I am unable to.  Please help with this!
ennujozlagam
hi have you try to untick the use hardware acceleration and try to updates latest updatesand hot fixes from autodesk.
if you want to change background to white go to options > graphics > volors > background, change to white. thanks
ChrisNeedhamNZ
I think you must have a view template assigned to the view.
Either remove the view template, then change the background, or change the settings in the view template.
Chris Needham
Whangarei
New Zealand
yes i think you are right
wwright
Sometimes (after working in Revit for a while), I will attempt to render to the cloud, but the dialogue box is blank.render in cloud.JPG
Has anyone experienced this problem? When I restart Revit, it works as normal (for a while), but the model is large and takes a while to load (hence, slowing down my roll).
