Rendering Colour Doesn't Match Shaded View Colour
Hello everyone,
Running into a problem on Revit 2021. When I render my 3D view, it goes from the colour scheme I want into a generic-looking gray/cream-ish look for the rendered view. The same also happens to my site topography, weirdly enough. I've attached the files of the screenshots as well.
I'm sure it's just a minor settings issue with the materials visibility, but I would just like some help since this is part of a course project.
constantin.stroescu
Shading and Rendering are two complete different way of presentation, each one with different settings.
Shading is a graphical presentation method(non photorealistic) controlled by Graphics, while Render controlled by Appearance means Photorealistic presentation and you have to allocate Material properties in order to obtain the desired effect .
Constantin Stroescu
hmunsell
What are the material setting of the elements in your model? the images imply that you have a Graphics color set, but no actually Material.
  • select a wall
  • Edit Type
  • pick the Structure button
  • make sure the Exterior Finish is set to a material (it should not say "By Category")
    • pick the Appearance tab and make sure it is mapped to an appropriate material.
  • do this for other elements as well (Roof, Windows, Topo, etc....)
Howard Munsell
Hello Constantin,
I tried out the solution you recommended and it looks like it's all working properly now in the rendered view! Thank you so much!
