Rendered Shadows To Dark
AloraVZ
Observer Observer
AloraVZ
Observer
Observer
When I render a 3D floor plan, the shadows casted onto the floor are rather dark and sharp. I already lowered the shadows in the render settings to the lowest they'll go. I've looked up solutions but haven't found any that actually made them appear lighter. I attached a picture of an example.
Ahmed_M_Heteba
A few things you can check:
  1. Sun Settings
    • Go to Graphic Display Options - Sun Settings.
    • Try switching from Still to Lighting - Interior: Sun Only or Sun and Artificial to soften the contrast.
  2. Sun Intensity
    • In Render Settings, reduce Sunlight Intensity and increase Artificial / Ambient lighting if available.
  3. Location and Time
    • If the sun angle is very low (morning/evening), shadows will appear sharper and longer.
    • Try adjusting time of day closer to midday.
  4. Exposure Control (after render)
    • Open the rendered image and adjust Exposure Settings.
    • Increasing Highlights and Shadows brightness usually softens dark shadow areas.
  5. Materials / Floor Reflectance
    • If the floor material has very low reflectivity, shadows will look darker.
    • Increasing material reflectance or brightness can help balance the lighting.
Ahmed Heteba, PMP, bsi, B.Sc, AEE, ACI, ACP
Senior BIM Manager @ EllisDon
AloraVZ
Observer
Observer
Thank you for the advice, I'll try your suggestions out and see if it fixes the issue.
