rendered image download
Message 1 of 8
can rendered image be download from cloud to hard drive?
Replies (7)
Message 2 of 8
Hey there.
Yes you can. On the gallery, click at the arrow in the botton-right side of each image and choose the option Download Image. Example:
If your problem has been solved, please click on Accept as Solution. Then others users can take benefit of it.
Felipe Góes
Autodesk Instructor
Message 3 of 8
about how long did that sample image take to render in the cloud?
Message 4 of 8
It depends on your computer configuration. It can take minutes to several hours..
The most important things are: CPU, RAM and graphic cards.
You can check the specifications suggested here: https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
Felipe Góes
Autodesk Instructor
Message 5 of 8
why does my computer build have any affect on rendering time in the cloud? I a trying to learn more about Revit LT, where rendering is done in the cloud.
Message 6 of 8
Sorry.
Those hardware's configurations are for the PC render. For rendering in the cloud, all you have to be sure is the internet connection is stable and fast.
Message 7 of 8
ok. let's assume a reasonably adequate residential internet connection (comcast.) how long will a cloud render take to perform, of an exterior view of a new single family residence?
Message 8 of 8
dgorsman
Rendering is something of a dark art.  There is no direct calculation to estimate the time required.  Even a similar model between different users may have different rendering times due to selection of materials, use of lighting, number of passes/quality settings, render engine, and even how busy the cloud server is at the time.
Most renders should be available same-day.  With optimization for rendering it may only take an hour or two.  That's assuming nothing else is holding up the queue.
