render problem
render problem
ennujozlagam
Mentor Mentor
render problem
ennujozlagam
please help me to set my render defaults configuration/setting, because i render my drawing it look like disturted and the colour is blurry. just give the correct setting configuration so that my drawing looks better. thank you..
ryan.duell
If you are experiencing this issue in a view, I would recommend doing the following:
-Open View with issue.
-Click “Show Rendering Dialog”.
-Change “Quality Setting” > High.  The predefined settings should be read only.
-Next, click Image > “Adjust Exposure”.  Click “Reset to Default”.
-Then click “Render”.
Please let us know if the issue persists, and if so please attach an image example of the output for further review.
Thank you,
Ryan Duell
ennujozlagam
hi ,
i think the problem havent solve yet,
1) the render colour  looks like smashed.
2) why is it my glass panel didnt (curtain wall) show up in my render.
3) anything i need to know how to set configuration when rendering?
attached some files for you to see. thanks a lot.
