render problem
render problem
ennujozlagam
Mentor Mentor
910 次查看
2 条回复
1 条消息(共 3 条)
render problem
ennujozlagam
please help me to set my render defaults configuration/setting, because i render my drawing it look like disturted and the colour is blurry. just give the correct setting configuration so that my drawing looks better. thank you..
0 个赞
已接受的解答 (1)
911 次查看
2 条回复
回复 (2)
2 条消息(共 3 条)
ryan.duell
已接受的解答
If you are experiencing this issue in a view, I would recommend doing the following:
-Open View with issue.
-Click “Show Rendering Dialog”.
-Change “Quality Setting” > High.  The predefined settings should be read only.
-Next, click Image > “Adjust Exposure”.  Click “Reset to Default”.
-Then click “Render”.
Please let us know if the issue persists, and if so please attach an image example of the output for further review.
Thank you,
Ryan Duell
0 个赞
3 条消息(共 3 条)
ennujozlagam
hi ,
i think the problem havent solve yet,
1) the render colour  looks like smashed.
2) why is it my glass panel didnt (curtain wall) show up in my render.
3) anything i need to know how to set configuration when rendering?
attached some files for you to see. thanks a lot.
0 个赞
