Render option greyed out
Message 1 of 12
Hi all. I've tried everything but my "Render" option under "View" is greyed out and not selectable. I've tried the following based on all the research I could find online:
1. Made sure I'm in a 3D view.
2. Made sure I don't have a crazy scale.
3. Created a new 3D view/duplicated it.
4. Uninstalled and Re-installed material libraries (in order). (I don't get the rendering disabled error at startup).
5. Uninstalled and Re-installed Revit.
6. Added "AdditionalRenderAppearancePaths=..\..\..\Program Files (x86)\Common Files\Autodesk Shared\Materials\Textures\1\Mats" to my Revit.ini file.
Not sure what else to short of wiping my system clean. Any tips appreciated.
Thanks!
Replies (11)
Message 2 of 12
ennujozlagam
Have you try camera view? Thanks
Message 3 of 12
pendean
Community Legend
Community Legend
Message 4 of 12
@pendean Thanks for the reply, but as mentioned in my original post, I've already checked to make sure I'm in a 3D view.
@ennujozlagam Even camera view doesn't work. Option is still greyed out.
Message 5 of 12
pendean
Community Legend
Community Legend
The link/tip also suggests creating a new 3D View to render.
Message 6 of 12
ennujozlagam
Then try to install latest updates from autodesk and see if helps. Thanks
Message 7 of 12
Thanks for the additional suggestions. I do have all the latest updates installed, and I have tried using the camera option, but still have the "render" greyed out.
Message 8 of 12
What happens if you type in RR?
Message 9 of 12
Typing in RR does nothing. Double checked and made sure it's still associated with render, but it doesn't do anything.
Message 10 of 12
Can you open the Material manager?
Message 11 of 12
Thanks for all the replies. I contacted Autodesk support and it turns out I had to rebuild my Windows user profile. Not sure what happened, but somehow some files/info/something got corrupted with my user.
Message 12 of 12
jeffreygriffin56
One more thing to check.
Check your view template, you may have it set to a view template that will not let you change render options.  Set the view template to <none>.
