Hello, I have a problem with rendering mateials, I obviously do some mistake in settings. When I try rey trace view, the water and grass are really great (on the right), but when I send a render (high resolution) specially the water is intransparent and not realistic. Could you help me, please?
Try changing in material appearance property, the height of the wave to zero or type to reflective pool. It may help.
Hello, thank you very much - it is better, but stil it changes just when I preview it like a ray trace - when I do render, it is still just more blue mass (waved mass) but the texture is not so pretty as I saw in raytrace. Am I missing some button in render options? Because it is the same view, I have rendered in on the best quality, but the grass and water worse than on raytrace. Thank you!
Because in the left picture - it is the render and the water is not as great as the raytrace on the right. Thank you very much that you replied.
