How hard can it be?
Apparently all I have to do, is rename in BIM360. Then open it.
Except I've done this, then waiting ages for it to download the file via ACCDocs (this seems to be required now ALL OF THE TIME????), to find some problem or other that means I can't do anything with the project, or reference files get lost, or something.
Is there a method that actually works, that won't see me spending yet another half day doing something should be simple?
Note: The firm I work for recently did an update of ACCDocs. This is causing significant problems now with managing Revit files, for myself and others, as what was previously simple via the BIM360 Cloud site, now seems extremely difficult, with hours wasted doing simple things.
Solved by ennujozlagam. Go to Solution.
try this and see if helps. thanks
no worries. thanks
