Having a problem with unwanted roof eves and i know there will be more instances like this. Does anyone have a method of removing them??
Solved by ToanDN. Go to Solution.
Edit the footprint of the roof. You can remove the eaves there.
thanks for the input but It does not give me the option, is there any way to freeze the ridge? My rear roof is lower than the front roof and when i move the overhang it effects a number of other issues. thanks in advance
It will give you this option when you select and edit the roof footprint. In sketch mode select one of the pink sketch lines. That will bring up the option highlighted in my previous post.
Thank you for the response, will follow your advise. can i do the same if my gable is in line with eve? Or must i treat it as a dormer?
You can do the same.
Even if you make it with two roofs and join them together, you could still cut a triangle out of the footprint of the main one.
