Removing roof eves
7 REPLIES 7
Message 1 of 8
1353 Views, 7 Replies
Removing roof eves
Having a problem with unwanted roof eves and i know there will be more instances like this. Does anyone have a method of removing them??
Tags (1)
7 REPLIES 7
Message 2 of 8
Sahay_R
Edit the footprint of the roof. You can remove the eaves there.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Message 3 of 8
in reply to: Sahay_R
thanks for the input but It does not give me the option, is there any way to freeze the ridge? My rear roof is lower than the front roof and when i move the overhang it effects a number of other issues. thanks in advance
Message 4 of 8
You can model the roof and the dormer as a single roof so you don't have to worry about the piece.
Message 5 of 8
Sahay_R
It will give you this option when you select and edit the roof footprint. In sketch mode select one of the pink sketch lines. That will bring up the option highlighted in my previous post.
Rina Sahay
Message 6 of 8
in reply to: ToanDN
Thank you for the response, will follow your advise. can i do the same if my gable is in line with eve? Or must i treat it as a dormer?
Message 7 of 8
chrisplyler
You can do the same.
Even if you make it with two roofs and join them together, you could still cut a triangle out of the footprint of the main one.
Message 8 of 8
Sure, you can do it with the gable aligns with or offset from the edge . You can do it as one roof or two roofs join together.
