Good morning,
We are working with a multi-family project where each unit type is it's own link (there are about 8-10 separate links). The levels of each unit/link show up in our building and wall sections. I know I can hide level markers of individual links in the view template, but even this proves tedious with the amount of links and view templates.
The links are NOT workshared, so I can't turn off the workset through the manage worksets dialog of the link.
What is the best practice for these things? Can I replace the level in the link with a reference plane? I'd like a way to just turn them off universally.
Many thanks,
Aaron
Solved by ToanDN. Go to Solution.
so no workset in the link? the only way i think is possible is through Revit link and change "by host view" to "custom".
then create a view template with your settings.
You need to add a prefix to your Level Names then create a view filter to filter out any Levels don't have that prefix in their name.
