Removing Handrail extensions
Sahay_R
Mentor Mentor
Message 1 of 8
Sahay_R
I have used a railing style which came with extensions. How to I remove / edit the extensions?
Rina
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Replies (7)
Message 2 of 8
Message 3 of 8
Sahay_R
Hi again ToanDN - this is awesome information. Unfortunately the situation I am trying to remedy is this -
Rina Sahay
Message 4 of 8
The little C shaped piece?  If it is the extension of the top rail or the handrail then the procedure is the same as what I have shown.  If it is something else than you need to give more info or upload a model.
Message 5 of 8
Sahay_R
ToanDN - here you are. I am trying to remove the extension at one end of the railing so that it can die into a wall.
Thank you!
Rina Sahay
Message 6 of 8
artejon
Select a railing>edit type>baluster placement>edit>choose a different start and end post that haven't got the extension.
Revit add-ins: CAD Purger (delete UNUSED and selected line patterns & line styles, find and delete CAD), Rooms To Spaces, Schedule Utilities (Calculated Values/Combined Parameters To Tags, reuse view filter rules in schedule filters), View Filter Manager at Revit Apps Store
Message 7 of 8
Sahay_R
Toan - AWESOME!! This fixed it! Thank you!
Rina Sahay
Message 8 of 8
@rsahayUZMK9 wrote:
@artejon - AWESOME!! This fixed it! Thank you!
fixed it for ya 😉
