Parametric Room Boundary!
Hello All,
I have a parametric mass which I have defined room boundary for part of it. I wonder if there is any way to make a room boundary adjustable with the movement of the mass surfaces? I mean is it possible to make the room boundary parametric changeable?
Thanks for your time and suggestion.
Did you ask the exact same question and mark the solution yesterday? If the answer is not a solution, do not mark it as one and continue the discussion in the same thread.
@ToanDN Seems you didn't consider about the time I posted the Qs. I posted them at the same time in both Live Forum & Architecture, in such a case that I couldn't receive the answer in Live one...
"If the answer is not a solution", then why someone should mark it as a solution?
I don't wander over Live forum. Both of your messages appeared here in different times so someone must have moved one from Live to here (without the moving notice) after the first one got answered. It was a misunderstanding. Carry on.
Yeah it's moved.
That's fine.
