Remove Tag from an Element and Schedule
andy_bennettDKK55
andy_bennettDKK55
Community Visitor
Community Visitor
Hi, I created a device schedule to identify manufacturer/model of various electronic devices using the Tag by Category function.  However, I changed my mind about a few devices and don't want them tagged or in the schedule.  Specifically, I have (3) different types of wall mounts tagged as WM1, WM2, WM3 but I'm going to just identify them in a detail vs. incorporating into a schedule on the larger plan views given their nature. Removing the tag text from the various plan views was easy enough but I can't seem to figure out to remove the corresponding row from the schedule as the relationship between the element and the tag still exists in Revit.  I tried to delete the rows in the schedule with the tags I do not want to display but that then removes the elements form the model which I don't want.  I'm assuming that I need to remove the tag associated from the actual element(s) vs. editing the schedule, but can't figure out how to remove a tag.
Thanks in advance for any assistance!
Filter Elements out of the Schedule via a rule-based filter under the Filter Tab of the Schedule.
https://help.autodesk.com/view/RVTLT/2022/ENU/?guid=GUID-4E74B262-0555-4FBC-B26D-3F8B4A69A6AA
BTW: there is no correlation between Tags and Schedules.
handjonathan
Hi @andy_bennettDKK55
Thanks a lot for posting your question to the forums!   Has the solution suggested by @barthbradley helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
RobRocks
No, that's wrong. Tags pull information from the elements. You can remove a tag by deleting the element but deleting the tag does not remove the element. You need to edit the schedule as suggested.
