Remove split face pattern from linked file
Marcus.Isacsson
Message 1 of 26
Marcus.Isacsson
Hi!
I need to hide split face patterns from specific views with linked files. How can I achieve this?
Replies (25)
Message 2 of 26
you could try 'linework' tool
OR
set up and name views in the linked model - and refer through VG to look for those views in the linked model
Message 3 of 26
Marcus.Isacsson
OR
Linework tools doesn't seem to work on split face with material and I don't find in Visibility/graphics how I can turn on this single split face material.
Message 4 of 26
see attached
for this to work you have to make a view in the linked model that looks as you wish.... then call for that view in 'your' model
Message 5 of 26
Marcus.Isacsson
@Anonymous wrote:
see attached
Yes, but still..how do I achieve that in the created view?
I haven't figured out a way to make one material hide (inside split face). Do you know a way?
Message 6 of 26
Im not sure about your split face question (not sure you can?!)... however if it was me - I would cover it with a detail item filled region
Message 7 of 26
Message 8 of 26
Marcus.Isacsson
Seems SO weird that this isn't possible. But I think you might be right. If that's the case I'll try to avoid split face further on.
If you look at the picture it's quite hard to cover it with a filled region (want the door to show)
Message 9 of 26
i would do that with two detail items. one inside the door swing. one for 'the rest'..... 😉
Message 10 of 26
I would create a dedicated view in the link as @Anonymous has suggested, but instead of using masks, I would use linework tool to turn the split face lines to Invisible in that view, then use that linked view to display in your model.
p/s: nothing wrong with using a mask, just a different approach
Message 11 of 26
Marcus.Isacsson
Fellas, linework doesn't seem to work on split face. I've tried it.
Also, using masks like this sure will get tiresome for many views (and masking around a door). I think it's really odd that the pattern can't be filtered or something like that.
Message 12 of 26
youre not wrong .....
however given what it is - why not make two entities - instead of splitting the face? might save a bunch load of work?!
Message 13 of 26
Marcus.Isacsson
I agree, next time I'll use parts or separate floors instead. Split face is the work of the devil! 🙂
Message 14 of 26
It does.  Please watch below.  In fact I tried and it works on spit faces from a link as well.
Maybe you have something else going on.
Message 15 of 26
Marcus.Isacsson
You are hiding the line between two materials. That's not the problem here. The problem is hiding a pattern that the material has on the split face in this specific view.
Message 16 of 26
Be hold for another screencast.  And by the way, I too have given up using split face since Create Parts was introduced.
Message 17 of 26
chrisplyler
I forget - because I don't ever do it - but isn't there a setting to display links either "by the link settings" or "by the host settings? I would set it to display by the host settings, and then see if I couldn't turn off the surface pattern.
Message 18 of 26
Viveka_CD
Hi @Marcus.Isacsson
We wanted to check back in with you on this post. How is everything working out?
Let us know if further assistance is needed from the community on this post.
Please mark any posts that help with "Accept as Solution" and thanks!
Message 19 of 26
Marcus.Isacsson
@Viveka_CD wrote:
Hi @Marcus.Isacsson
I still haven't figured out how to hide the pattern of a selected splice face (not the other floors).
Message 20 of 26
Viveka_CD
Hi @Marcus.Isacsson
Did you try the recommendations from @ToanDN@chrisplyler and @Anonymous?
Can you send us your file to troubleshoot further? i can share a private folder if you'd like.
Let me know.
