Remove Recent project listed
5 REPLIES 5
brianwclayton1969
4187 Views, 5 Replies
How can you remove recent listed projects on the main opening screen?
Where you only have the Sample Project listed.
All ideas or directions are appreciated.
5 REPLIES 5
You either move those two files to another location so it won't show up or delete them. You can also rename the file to trick Revit into thinking this is a new file and it won't display on the startup screen.
1. Options=>User Interface=>Uncheck "Enable Recent File List at Home".  Restart.
2. Revit.ini File=> Recent File List Settings
in reply to: brianwclayton1969
Thanks I appreciate the assistance, I relocated the files to another folder.
Brian
RobDraw
Did that actually work or did you also disable it as @barthbradley suggested? I thought Revit would make new files if they weren't present.
Rob
