Remove glass from glass panel railing
emmanuelbee
emmanuelbee
Is there way a way to remove the glass from the glass filled panel railing? I can't seem to find anything in the balustrade settings that will let me do that
Excess length fill = None?
Ha! I'm reading this totally different from @ToanDN "Is there way a way to remove the glass from the glass filled panel railing"?. Sure. Change it from a glass filled panel.  You don't just remove a portion of a family. You are either using it or you are not.  Or am I reading you too literally.  If so; sorry.
emmanuelbee
Yes I just couldn't find the settings that would allow me to change the glass panel to none but I found it now
@emmanuelbee: SERIOUS? I must have completely misinterpreted you. What method did you use to "change the glass panel to none"
emmanuelbee
Excess length fill has to be set to none
Well, that proves it....@ToanDN's the master interpreter. He was dead on balls accurate.
