This is what I have been doing (with probably too many steps), but it works with multiple buildings on one site.
Short version: "Create a Site.rvt file that keeps the dwg with real coordinates and publish them to the Building file"
Long version:
1. Create a blank Revit file named Site.rvt
2. In Site.rvt, create a level (TOPO LEVEL) at the elevation you want for your Building (your case - 615m)
3. Link the dwg file in Level 1 (0.00m). You should be able to see it now in the TOPO LEVEL Floor plan.
4. Go to Manage - Coordinates - Acquire Coordinates and click on the dwg.
5. Save the Site.rvt file.
6. Create your Building.rvt file and draw 2 grids or intersecting walls. These will allow you to position the Building on the exact coordinates in the Site.rvt file
7. Close the Building file and link it (Origin to Origin) in the Site.rvt file. It will be on Level 1 in the Site file.
8. Go to an Elevation View and move the Building link up to the TOPO Level
9. Go to TOPO LEVEL view and move and rotate the Building file to its actual coordinates (you can use snaps in the dwg)
10. Go to Manage - Coordinates - Publish Coordinates and select the Building link. It will ask in which position would you like to save the new coordinates.
11. Save the Site.rvt file. Revit will say that the location position changed. Pick Save the new position back to the link.
12. Close the Site file and open the Building file. The coordinates should be the ones from the Site file.
13. To check, link the Site file in the Building file using the Shared Coordinates option.
