Rejoin horizontally split walls without losing hosted windows, etc..
Aidenj
Message 1 of 23
Aidenj
Hi there,
I'm trying to learn how to rejoin horizontally split walls.
Simply dragging the wall borders into each other does not make them one again.
I have seen advice given to simply delete one wall and then raise or lower it to suit.
However - when the walls in question host windows and other families,
this solution causes all of them to be lost - which is a huge time waster.
Any ideas out there?
Thanks!
Aiden
(ps - if necessary, I can explain why I need a reconstituted wall - it has to do with the way certain wall families deal with built-in reveals.)
Replies (22)
Message 21 of 23
Use Join geometry tool to join the walls and the openings cut all of them.
Message 22 of 23
Aidenj
Hey thanks for the helpful tip!
Message 23 of 23
FLUXPLANNING
use the join tool to join the second wall to the wall hosting the windows.
The window opening cut will then automatically cut the second wall
