product performance
product performance
product performance
Is there a phone number to talk to an actual person about issues with the Revit program?
ennujozlagam
hi, you can post here whatever issue you have encounter maybe we can help. or you may check your resseller in your area where you bought your program.
and you may check it here. hope t helps. thanks
http://usa.autodesk.com/adsk/servlet/index?id=1073074&siteID=123112
these are the support options: http://www.autodesk.com/subscription/technical-support
which one was bought with the software?
have you tried contacting a reseller in your area for help?
if your on active subscription you can create cases directly with autodesk by logging on to your autodesk account: http://knowledge.autodesk.com/customer-service/account-management/subscription-management/support-options/web-support/submit-view-cases
