Reivt 2020 realisitic elevation color show dark brown
wjxu55
wjxu55
Please help me resolve the problem of Revit 2020 realistic elevation color showing dark brown. It is not the correct color. Please see the attached image. Thanks
jay_colc
Realistic uses the render material settings. First check that the Render Materials are set as expected for each elements.
For instance, the solid representing the actual glass is set to the "Glass" subcategory in the family. Then check that it has a material parameter set for it. Finally, check that the material parameter for that family in your project is set to a glass material that will be transparent in rendered and realistic views.
Also - Is your wall cut by the void in the door/window family?
Jay Colcombe
Autodesk Certified Instructor
Set View Phase Filter to Show Complete.
...more odd to me is the Windows. They don't look right. Looks like they aren't cutting the Wall.  Maybe there's another Wall from a previous Phase there.
syman2000
Upload the sample file so we can take a look.
wjxu55
Thanks for everyone. The problem is fixed by setting phasing to Show Complete. The previous phasing was set to show previous+demo.
