Reinstalling content pack
victorbunster
victorbunster
Hi
I ran into some configuration problems and had to clean uninstall Revit 2024. I managed to re-install it and now it is working, but as part of the process I removed the Australian content pack manually. Now, when I try to re-install it I get this message:
But the library is not in its original location:
I cant find any way to uninstall it. I used Everything to check if the files are somewhere lost in the hard rive but not.
Any help would be much appreciated.
vitorbortoncello
The only way i know to really make this work is reinstall Revit entirely.
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | BIM Manager
dAutodesk Certified Professional
victorbunster
Thanks @vitorbortoncello
I just uninstalled and re-installed everything, but I am getting the same message.
Any other ideas?
victorbunster
I found a solution, there is an uninstall tool under Autodesk:
This removed all the files and allowed me to re-install
