Reinstall or fix content pack
victorbunster
victorbunster
Hi
I had to remove and re-install Revit 2024, and in the process I manually deleted the Australian content pack. Now when I try to re-install it, I get a message saying that the pack is already installed. The files are not in C:\ProgramData\Autodesk\RVT 2024\Libraries or in my hard drive.
Is there any way to fix this?
ridantuo
Don't uninstall manually in the future; uninstallers uninstall everything properly like registry data etc.
Did you try manual installation? Repair function of the uninstaller could also do the trick.
https://www.autodesk.com/support/technical/article/caas/tsarticles/ts/2BQRb68xV4vUxhiNWfnv7k.html
PICNIC: Problem In Chair Not In Computer.
Around 90% of issues can be explained by human error instead of an actual error.
victorbunster
Thanks @ridantuo
I uninstalled following these steps, but I could not re-install Revit, so I used the uninstaller. That did work, but now I cannot see or re-install the content pack. I am trying to install it manually, but I get this message:
When I go to "Uninstall or change program" is not there:
Also not in my libraries:
There must be a file in the system registry or somewhere telling the installer that the files are there.
Any ideas? Thanks
victorbunster
I just found a solution...
There is an uninstall app under Autodesk/Uninstallers:
This removed all the files and was able to re-install it.
RSomppi
You must have missed the first responce.
Message #2.
